  2. Functional Verification
  3. Help needed in creating URM using SV
  • Replies 15
  • Subscribers 66
  • Views 26451
archive over 19 years ago
Hello friends!
I'm facing a problem while creating my Verification IP using SV language in URM environment.
Right now, I'm just trying to up my master agent with these files:
package.sv
dut_interface.sv
master_sequence_driver.sv
master_interface.sv
master_bfm.sv
master_monitor.sv
master_agent.sv
dut_dummy.v
dut_wrap.sv
bus_interface.sv
I got two errors"An interface connection must be connected to verilog parent" and "An interface port declaration must be connected".....
I couldn't able to go further....can anyone help me in this regards!?
Thanks in advance!
Jalli
Originally posted in cdnusers.org by jaally
    Hi Jalli.
    You get these messages if you have not connected the SV interfaces correctly to your agent or DUT.
    If for example you DUT has a port declared as an interface, it must be connected to an interface of the same type.
    Without seeing your files it's hard to pinpoint the exact error, but I suggest you double check the connections from you top file going into the agent and DUT instances.
    You can send me the files if you don't manage to resolve it : stephenh cadence.com
    By the way, when you get an error message that you don't understand, try looking it up using the nchelp command. This usually gives some more details about the problem and how to solve it. For the two messages you described I pasted the nchelp commands and the output:
    [sve/main] $ nchelp ncelab CUINMD
    nchelp: 06.11-s003: (c) Copyright 1995-2007 Cadence Design Systems, Inc.
    ncelab/CUINMD =
    This is an incompatible connection. A Verilog interface must be connected
    to a port of a Verilog instance. All other languages and connection
    types are disallowed.
    [sve/main] $ nchelp ncelab CUIMBC
    ncelab/CUIMBC = An interface port declaration may not be left unconnected.
    [sve/main] $
    Originally posted in cdnusers.org by stephenh
    Sorry, the forum mashed my example. Here it is again:
    ncelab/CUINMD =
    ncelab/CUIMBC =
    Hi Steve!,
    Thanks a lot for your instant reply!!!!!
    I've seen your reply and I've sent the code to your mailID..i.e., "stephenh@cadence.com"
    I've corrected all the possiblities you've mentioned and also I use nchelp frequently for any error I get but for this problem I couldn't get the solution.....so plz help me in this regards. Please do letme know whether your mailID is proper or not as mentioned here.
    Thanks in advance,
    Jalli
    The port connection to the UVC includes the dut_if. Therefore, make sure you have a top level that instantiates the dut_if and then connects it to the port of the UVC.
    Example:
    module top;
    ahb_interface dut_if (); // must instantiate interface
    ahb_uvc env (dut_if); // and connect it to module with interface port
    endmodule
    module ahb_uvc (interface dut_if);
    endmodule
    Tim
    Originally posted in cdnusers.org by tpylant
    Hi Jally.
    I just replied to your mail with some more info. For the record, because you have only compiled the agent, and no env or testbench to instantiate the agent, the agent's interface is left unconnected, which is illegal in SystemVerilog.
    You should refer to the URM docs, and also the vr_xbus example that comes wit IPCM.
    You can find the vr_xbus example files under the IPCM installation, like this:
      IPCM/6.11/ipcm/urm_lib/sv_mb_ex_lib/vr_xbus
    Normally your testbench hierarchy would look something like this:
    sve   (top module)
     |- dut_if   (instance of dut interface)
     |- dut_wrapper  (instance)
     |     |- dut   (the real dut)
     |- sips_ahb_env  (instance of the AHB env)
     |    |- sips_ahb_master_agent
     |    |    |- sips_ahb_master_monitor
     |    |    |- sips_ahb_master_driver
     |    |    |- sips_ahb_master_bfm
     |    |- sips_ahb_slave_agent
     |    |    |- (structure as per master agent)
     |- any_other_interface_env
          |- any_other_interface_master_agent
          |     |- any_other_interface_master_monitor
          |- any_other_interface_slave_agent
    Hi Steve,
    Thanks once again!....I'll rectify my code and let you know very soon about it!
    Jalli
    Hi Steve,
    It worked out after I created any_other_env.sv and any_other_tb_top.sv......Error gone!
    Jalli
    Hi Jalli.
    Glad to hear you fixed the problem :-)
    We always recommend that you build the whole URM structure (env, master and slave agents).
    If you do this, it has several advantages, including:
    1) Consistent structure, so your code is more understandable.
    2) You can develop the protocol without needing a real DUT (master agent talks to slave agent for verif env bring-up).
    3) You can use the inactive part (e.g. slave agent) as a passive monitor of your DUT.
    This is most helpful when you have multiple slaves and you want coverage or checking on each slave DUT.
    There's loads more reasons, but those are a good start :)
    Hi Steve,
    Ok....I'll do accordingly....right now I'm concentrating on writing the code for slave agent!
    Thanks a lot for your suggestions and guidance!....I'll follow accordingly and will definetly seek your help if I get struck somewhere!
    Jalli
    Hello Steve,
    My environment is up but I've a warning based on system task which is shown as below:
    vb = $urm_get_message_verbosity(module_path);
    ncelab: *W,MISSYST (./examples/urm_util_pkg.sv,263|32): Unrecognized system task or function (did not match built-in or user-defined names) [2.7.4(IEEE Std 1364-2001)].
    if ($urm_is_severity_defined())
    ncelab: *W,MISSYST (./examples/urm_util_pkg.sv,458|30): Unrecognized system task or function (did not match built-in or user-defined names) [2.7.4(IEEE Std 1364-2001)].
    sv = $urm_get_check_severity(module_path);
    ncelab: *W,MISSYST (./examples/urm_util_pkg.sv,464|29): Unrecognized system task or function (did not match built-in or user-defined names) [2.7.4(IEEE Std 1364-2001)].
    Can you please tell me in which system file these tasks are included so that I can remove these warnings by including those files!!?
    Thanks a lot in advance!,
    Jalli
