  2. Logic Design
  3. Warnings when synthesis using RTL compiler
  • Subscribers 63
  • Views 20191
Greatrebel
Greatrebel over 16 years ago
 Hi All,
When I use RTL compiler to synthesis my design, I found there were a lot of warnings like
"The following sequential clock pins have no clock waveform driving them" and
"Referenced signal not in sensitivity list.  This may cause simulation mismatches between the original and synthesized designs." during elaboration.
 I am wondering whether these warnings are serious, can I ignore them.
 Thanks in advance
  • grasshopper
    grasshopper over 16 years ago
     Hi Greatrebel,
     I hope you realize that if the warnings were not meaningful, they probably would not be there. seq. clock pins is pretty bad since why would you have flops without clocks? Incomplete sensitivity list has minimal impact for synthesis but could lead to all sorts of issues for simulation.
    good luck,
    gh-
  • Greatrebel
     hi grasshopper,
     I guess the warning "sequential clock pins have no clock waveform driving them" is caused by missing assignment to some registers in some case branches and using another signal for posedge. My code is something like below
    assign clk_spi = cpol ^ cpha ^ sclk; //sclk is synchronise clk not system clk
    always @ (posedge clk_spi or negedge rst)
    if (!rst)
                begin
                    bit_cnt <= #1 3'b0;
                    byte_cnt <= #1 3'b0;
                    state <= #1 `IDLE;
                    spi_instr <= #1 8'b0;
                    read_mem <= #1 `INST_WIDTH'b0;
                end
            else
                begin
                    bit_cnt <= #1 next_bit_cnt;
                    byte_cnt <= #1 next_byte_cnt;
                    state <= #1 next_state;
                    spi_instr <= #1 next_spi_instr;
                    read_mem <= next_read_mem;
                end
    If I use system clk instead of clk_spi, it seems like the warnins gone.But I need that signal for those registers. So I can not have clockconstraint on those registers.
  • grasshopper
    Hi Greatrebel,
    the RTL without the timing constraints is not terribly helpful since I people cannot tell what or how you defined the clocks. Also note that for clock propagation purposes most synthesis tools do not use the logic function but instead the unateness of the cells as defined in the libraries.
     gh-
  • mohammad083
    mohammad083 over 9 years ago
    Hello Greatrebel,
    I am facing the same "Sequential clock pins without clock waveform
    The following sequential clock pins have no clock waveform driving them. No
    timing constraints will be derived for paths leading to or from these pins" problem while synthesizing my RTL code.
    Did you ever get around to fixing it?
    Azhar
  • grasshopper
    grasshopper over 9 years ago
    If you care about simulation mismatches or sequentials without a clock, they are indeed serious and should be taken care of
    gh-
