  2. Data Center
  3. Designing AI Factories with Digital Twins
Reela Samuel
Reela Samuel
Digital Twins
2 Mar 2026 • 6 minute read
Engineering AI infrastructure as a performance system
Designing AI Fcatories
The role of the data center is changing. What was once built to run applications is now engineered to operate as an AI factory. An AI factory is a purpose-built computing environment designed to create value from data across the full AI lifecycle, from data ingestion and model training to fine-tuning and high-volume inference. Its output is intelligence, often measured in token throughput that drives decisions, automation, and new digital services.
This shift is fundamentally changing how infrastructure is designed. Performance is no longer determined solely by compute. It depends on how effectively power, cooling, facility systems, and workloads operate together as a single system.
Only a few years ago, high density meant 10 to 20kW per rack. Today, GPU clusters routinely exceed 100kW, with some deployments moving toward megawatt-scale configurations. Power delivery systems operate close to capacity. Hybrid air and liquid cooling must respond to rapid workload-driven thermal changes. In many regions, grid availability has become a primary constraint on expansion.
In this environment, building capacity is no longer the primary challenge. Engineering predictability at the system scale is.
Why AI Factory Design Is More Complex Than Traditional Data Centers
AI infrastructure is assembled through a distributed ecosystem. Compute platforms are developed by server and GPU vendors, power and cooling technologies are supplied by specialized equipment manufacturers, and facility teams design the building and physical infrastructure. The operator must integrate these elements into a working environment that meets performance and efficiency targets.
The lifecycle typically unfolds in three phases:
  1. Independent design by IT, facilities, and equipment suppliers
  2. Site construction and system installation
  3. Final integration and operational tuning
It is this final integration phase that carries the greatest risk. Interactions between subsystems are difficult to predict. Small mismatches can create thermal hotspots, stranded power capacity, inefficient cooling operation, or costly redesign after deployment.
Traditional planning approaches rely heavily on assumptions and conservative safety margins. While these reduce risk, they increase capital cost and lower usable compute density. As power densities accelerate, assumption-driven design is no longer sufficient.
From Components to System-Level Building Blocks
A new approach is emerging based on behavioral digital infrastructure models that represent how systems operate under real workloads rather than relying on static specifications.
Within the Cadence Reality Digital Twin Platform, complete AI environments, such as an NVIDIA DGX SuperPOD based on GB200 systems, can be modeled as validated operational building blocks. These digital elements are developed in collaboration with ecosystem partners and validated against supplier data, providing a high-confidence representation of real system behavior.
Instead of modeling generic IT loads, operators can simulate how actual AI clusters interact with facility infrastructure. This allows teams to answer critical questions early in the design process:
  • How much AI capacity can be deployed within available power limits
  • Whether hybrid cooling strategies will maintain thermal stability under peak workloads
  • How layout decisions affect electrical efficiency and airflow performance
  • Where reliability or capacity risks may emerge before construction
By transforming supplier data into reusable system-level models, digital twins bridge the gap between equipment design and facility integration.
Designing to Performance Targets Instead of Safety Margins
Every AI factory must meet defined service-level objectives for throughput, availability, and operational efficiency. The challenge is uncertainty about how subsystems will interact under real operating conditions.
When interactions are unclear, engineers compensate with conservative margins. This often leads to overprovisioned infrastructure and a higher cost per unit of compute.
Physics-based system simulation changes this equation. Higher-fidelity models allow infrastructure to be engineered directly to operational targets rather than worst-case assumptions. Operators can safely increase usable IT load within the same power envelope, evaluate failure scenarios before deployment, and reduce excess capacity.
In many AI environments, power is provisioned 20% to 30% above average demand to accommodate localized workload spikes. Simulation enables more precise planning, helping recover stranded capacity while maintaining reliability.
The result is improved cost efficiency and more predictable performance across the lifecycle.
Beyond CFD: Digital Twins for Hybrid AI Cooling
Computational fluid dynamics (CFD) has long been used to analyze airflow and temperature distribution. AI factories require a broader perspective that reflects the interaction of multiple physical domains.
Modern digital twins integrate:
  • Air and liquid cooling behavior
  • Electrical distribution and conversion losses
  • Workload-driven power variation
  • Containment and layout strategies
  • Operational changes over time
The Cadence Reality Digital Twin Platform uses a data-center-optimized simulation engine to evaluate complex hybrid cooling environments and high-density configurations efficiently. This cross-domain visibility allows engineers to understand system interactions rather than optimizing each domain independently.
For GPU-dense environments, this system-level perspective is essential to maintaining performance stability at extreme density.
The Real Bottleneck: Understanding Extreme Density
The primary constraint in AI factory deployment today is not the availability of hardware. It is the lack of proven design tools and operational knowledge for extreme-density environments.
AI workloads introduce new operating characteristics:
  • Rapid power transients during training cycles
  • Localized demand spikes across GPU clusters
  • Dynamic thermal hotspots
  • Highly variable utilization patterns
Physical prototyping at this scale is costly and slow. Virtual prototyping through high-fidelity simulation is becoming the primary method for understanding system behavior before deployment, similar to engineering practices in the aerospace and automotive industries.
Connecting Workloads to Infrastructure Performance
Training and inference workloads generate distinct power profiles that directly influence power distribution efficiency, cooling system response times, thermal stability, and overall energy consumption.
When application behavior is modeled alongside physical infrastructure, operators gain visibility into how workload placement affects facility performance. This enables better capacity utilization, reduces stranded resources, and improves overall efficiency.
Managing the AI factory as a workload-aware infrastructure system is emerging as a key operational capability.
Digital Twins Across the Full Lifecycle
AI infrastructure evolves rapidly, making static design models insufficient. Lifecycle digital twins provide value before commissioning, during deployment, and throughout ongoing operations.
Before commissioning, they support site selection, capacity planning, design evaluation, and risk identification. During commissioning, they validate performance against design expectations and enable operator training using realistic scenarios. After deployment, they help plan capacity expansion, evaluate hardware upgrades, predict thermal risk during peak demand, and analyze maintenance or failure scenarios.
When connected to live telemetry and monitoring systems, the digital twin becomes a real-time operational model that continuously reflects the physical facility. Over time, it evolves from a design tool into a decision platform for ongoing optimization.
Enabling Extreme Co-Design Across the Ecosystem
AI factories represent a fundamental shift in infrastructure engineering. Performance now depends on how effectively energy, cooling, compute, and workloads operate together under tight power and sustainability constraints.
Organizations that adopt system-level simulation and lifecycle digital twins can deploy capacity faster, reduce integration risk, and improve the cost per unit of AI output. Environments such as the Cadence Reality Digital Twin Platform, supported by multiphysics technologies like the Cadence Celsius Studio, enable infrastructure teams to evaluate complex interactions early and operate facilities with greater confidence.
As AI workloads continue to scale, the most efficient infrastructure will be designed, validated, and optimized virtually before it is built. In the era of accelerated computing, the digital twin is becoming the operational foundation for engineering AI factories at system scale.
See How Your Data Center Will Perform Before You Build or Modify It
Planning a new data center or scaling an existing facility for higher rack densities, liquid cooling, or changing workloads? Connect with Cadence for a data center design assessment or live product demo. Our collaborative approach helps you visualize airflow patterns, uncover thermal risk zones, assess cooling effectiveness, and understand capacity constraints—so you can make confident, data-driven decisions earlier in the design process.
Discover Cadence Data Center Solutions
  • Cadence Reality Digital Twin Platform to simulate and optimize data center behavior across both design and operational phases.
  • Cadence Celsius Studio to analyze and manage thermal performance from the rack level up to the full facility.
Read More
  • Data Center Design and Planning
  • Data Center Cooling: Thermal Management, CFD, & Liquid Cooling for AI Workloads
  • What Is Power Usage Effectiveness (PUE) in Data Centers?
  • AI, GPU, and HPC Data Centers: The Infrastructure Behind Modern AI
  • Choosing the Right Data Center Strategy: Colocation vs Hyperscale vs Enterprise
  • Data Center Operations, DCIM, And Monitoring
  • Data Center Digital Twins: How Simulation Improves Design and Performance
