  3. How to build a standard cell model (for a printed transistor...
  • Replies 11
  • Views 21358
How to build a standard cell model (for a printed transistor) in Cadence
write2rammy
write2rammy over 16 years ago
Hallo,
        I have the model equations for a printed transistor (Quite different from BSIM3 and EKV models). Now I need to use this model in Cadence to simulate circuits. So when I place a nmos the simulator should use this model instead of BSIM3 or EKV.. I guess I can't model this using Verilog-A because I am not intending to do a behavioral modelling.
    Why can't you use VerilogA for this? This is comething that VerilogA is being increasingly used for - at least for initial implementation of compact device models.
    To get you started with VerilogA modelling of devices, I'd first of all advise putting this library in your cds.lib and looking at some examples:
    ahdlLib         $(inst_root_with:tools/dfII/bin/icfb)/tools/dfII/samples/artist/ahdlLib
    Within ahdlLib you'll see several cells with veriloga views:
    mos_tft - a thin film transistor model
    mos_level1 - a level1 MOS model
    n_jfet - a jfet model.
    If you want to see some more modern, (and more complex) device models in VerilogA, see
    http://www.nxp.com/models/mos_models/psp/ which covers the NXP/Penn State "PSP" model. In fact you might find it easier to look here: http://pspmodel.asu.edu/
    There are a few other places around that might be useful:
    http://www.bmas-conf.org/2008/2-3_Paper.pdf
    http://www.designers-guide.org/VerilogAMS/ - a collection of models, including links to the EKV model implemented in VerilogA.
    As for books on VerilogA and modelling:
    http://www.designers-guide.org/Books/#Kundert-2004
    http://www.springerlink.com/content/k72461p50036466p/
    The first is a good coverage of the language - the second looks as if it is specifically aimed at people writing transistor models (I have the first book, but not the second).
    Here's another example:
    http://www.designers-guide.org/Forum/YaBB.pl?num=1268789424
    The alternative is that it's possible to implement the model using the C model interface into spectre, but this normally would need epecialist assistance (we do not provide documentation for doing this out of the box). Please contact your account manager or customer support if you want to pursue that route. It's not for the faint hearted and normally would be used only if you have a very large number of instances that will be used, and have detailed experience of device modelling in simulators.
  • write2rammy
     Andrew,
               Thank you for your prompt reply. I will try doing it with Verilog-A. But can you explain the problems with using Verilog-A models for a large number of instantiations (mentioned in the last para of your reply).
    Whilst we've done a lot of optimization for VerilogA models representing compact device models, typically I wouldn't expect them to be as fast as a model written in C. I recall seeing figures of a factor of 2 speed difference (although your mileage may vary), and it depends on the number of other devices in the circuit, and so on (and very much on how well the model is written).
    So my point was that if you have a very large number of devices (tens of thousands, say, or more), then you may need the performance improvement gained by writing in C. However, we do have some large customers that have their own transistor models (e.g. variants of bsim3v3) and use these all the time.
  • write2rammy
     Andrew,
              Thank you for your reply. Also I found in the following links, an alternate method using a spectre or spice netlist.
    http://www.cadence.com/community/forums/T/14736.aspx
    http://www.cadence.com/Community/blogs/rf/archive/2009/01/07/tip-of-the-week-how-to-simulate-a-subcircuit-netlist-with-spectre-in-ade.aspx
    http://www.designers-guide.org/Forum/YaBB.pl?num=1191334088
            So, if I do a spice model, convert it to spectre model and then use it, will it give better speed than a verilog-A models.
  • write2rammy
     Sorry. The second link is incomplete. I have added the right one below.
    Now I'm confused. If you have a SPICE model file, you can use that directly in spectre (no need to translate the format as spectre can read SPICE syntax directly).
    I thought you said you had a set of equations - if so, that's not a SPICE model file. Iwas suggesting a solution to implement a model using that set of equations.
  • write2rammy
             Sorry for the confusion. I have to write the models either in verilog-A or spice. My question is if I write the model in spice and use in cadence, will it be faster than the verilog-A model?
    You're comparing Apples and Pears here. A SPICE model normally is referencing a built-in device model and just setting a set of parameters for that device model (e.g. setting the parameters for bsim3v3, bsim4, ekv, psp etc). Maybe a few parasitic devices around the device. A VerilogA model is a set of simultaneous differential equations (and some procedural code) which need to be solved.
    Provided the SPICE subckt model is not too complicated, it will probably be quicker to simulate. But impossible to give you a definite answer without knowing more.
  • write2rammy
     I thought I could write a standalone model using .SUBCKT and .ENDS. Now I understand your point.Thank you. So I will stick with verilog-A
    Maybe you can develop a subckt model based on structural components, but only you can know that - I don't have enough info.
