  3. Stair waveform based on text file
  • Replies 8
  • Subscribers 136
  • Views 12693
Martinsh
Martinsh over 4 years ago
Dear Sir,
How to generate a stair-like or sample-hold waveform basing on a text file with content as following format. It's better if there is a way to build a Verilog-a model for this stair-like voltage source.
# Time Voltage
T1 V1
T2 V2
Tn Vn
Thanks!
    ShawnLogan over 4 years ago
    Dear Martinsh,
    Mr. Beckett just responded to a question almost identical to yours that provides instructions for creating  a vector file to use in combination with a source. There are many ways to accomplish what you want and Andrew's suggestion is one you might consider. The Forum post with Andrew's response is at URL:
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/54168/why-doesn-t-a-non-repeating-sequence-simple-voltage-source-exist
    Shawn
  • Martinsh
    Martinsh over 4 years ago in reply to ShawnLogan
    Dear Shawn,
    Vector file gives a digital waveform which has only two voltage levels, logic low and logic high. But the waveform I want is an analog waveform. It has many voltage levels instead of Logic Low and Logic high. Following text gives an example:
    0us  1mV        ; Keep output 1mV until next time point (1us)
    1us  10mV     ; Keep output 10mV until next time point (2us)
    2us  50mV     ; Keep output 50mV until next time point (5us)
    5us  20mV    ; Keep output 20mV until next time point (10us)
    10us  22mV  ; Keep output 22mV until next time point
    Andrew Beckett over 4 years ago in reply to Martinsh
    This Verilog-A model will do what you want. Note the format of the file is slightly different from what you asked - it needs to not use engineering suffixes (see the comment at the top).
    `include "disciplines.vams"
    // Verilog-A model to produce a staircase (sample and hold)
    // waveform given a file with transition points. The format
    // of the file is time-value pairs (space separated). Note that
    // the numbers cannot have engineering suffixes, so for example
    // will look like this:
    // 0     1e-3
    // 1e-6  10e-3
    // 2e-6  50e-3
    // 5e-6  20e-3
    // 10e-6 22e-3
    module staircase(voutp,voutn);
    output voutp,voutn;
    electrical voutp,voutn;
    // file name with transition points
    parameter string fileName="";
    // delay time for each transition
    parameter real td=0;
    // rise fall for each transition
    parameter real trf=1n;
    // if non-zero, then waveform will repeat with this period
    parameter real repeatTime=0;
    integer fp,success;
    real tim,val,curval,offset;
    analog begin
      @(initial_step) begin
        fp=$fopen(fileName,"r");
        success=$fscanf(fp,"%f %f",tim,val);
      end
      // if repeatTime has been set, reset to beginning of file
      @(timer(repeatTime,repeatTime)) begin
        offset=$abstime;
        $fseek(fp,0,0);
      end
      @(timer(tim+offset)) begin
        curval=val;
        if(success<2) $fseek(fp,0,0);
      end
      V(voutp,voutn)<+transition(curval,td,trf);
    end
    endmodule
    The output waveform looks like this (this was with repeatTime=12u):
    ShawnLogan over 4 years ago in reply to Martinsh
    Dear Martinsh,
    Sorry! I did not understand this need from your initial description as the value of "V" was not clear to me.
    A piecewise linear voltage source (vpwl) allows one to specify its voltage value as a function of time. The values and times may be specified in the vpwl GUI or alternately read from a UNIX file. You can use design variables to set the voltage levels and transition times as well as equations. Have you considered this option? An example of an input file that uses design variables and equations is at the Cadence On-line support site at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000sv0OEAQ&pageName=ArticleContent
    with a full description of its periodic parameters (should you want to use these) in the Troubleshooting article at URL:
    support.cadence.com/.../ArticleAttachmentPortal
    Of course, you could also write veriloga code to use in a veriloga subcircuit to create the staircase waveform if you prefer. Andrew Beckett wrote some code in response to the Forum post at URL:
    community.cadence.com/.../staircase-function
    Finally, you might consider using an ideal D/A from the behavioral library and supply the digital code to create the waveform. A bus generator to create the digital codes from a UNIX file, such as the one I provided in the response to a Forum post at URL:
    community.cadence.com/.../1385087
    could be used.(The example is in the Dropbox link of that post.)
    I hope I correctly understood your question on my second try and some of these suggestions provide some insight!
    Shawn
  • Martinsh
    Thanks a lot, Shawn!
  • Martinsh
    Martinsh over 4 years ago in reply to Andrew Beckett
    Andrew,
    Thanks. Timer based solution is a good idea but there is another problem. When I run a Tran simulation, if the start time isn't 0s, for example start=8u, the output waveform is not expected. Do you have any idea on this problem?
    BR,
    Martin
    Martin,
    A small update to the model fixes this:
    // 0     1e-3
    // 1e-6  10e-3
    // 2e-6  50e-3
    // 5e-6  20e-3
    // 10e-6 22e-3
    output voutp,voutn;
    integer fp,success;
    analog begin
        // deal with non-zero start time for transient
        while(success==2 && tim<$abstime) begin
          curval=val;
        end
      end
        offset=$abstime;
        $fseek(fp,0,0);
      end
        curval=val;
      end
    end
    endmodule
  • Martinsh
    Thanks Andrew! It works well.
