  2. Functional Verification
  3. How to Compile System Verilog
  • Replies 10
  • Subscribers 68
  • Views 36064
System Verilog
System Verilog over 18 years ago
I use ncverilog: 05.70-s015: (c) Copyright 1995-2007 Cadence Design Systems, Inc.
TOOL:   ncverilog       05.70-s015:
and foll switches
    -update
    +access+r
    +sv31a
I egt the foll errs
class mem_base_object;
ncvlog: *E,EXPMPA (../models/mem_base_object.sv,3|4): expecting the keyword 'module', 'macromodule' or 'primitive'[A.1].
(`include file: ../models/mem_base_object.sv | line 3, `include file: ../models/memory_top.sv line 3, file: ../tb/memory_tb.sv line 4)
  mem_txgen txgen;
ncvlog: *E,ILLPDL (../models/memory_top.sv,11|16): Mixing of ansi & non-ansi style port declaration is not legal.
(`include file: ../models/memory_top.sv line 11, file: ../tb/memory_tb.sv line 4)
  mem_scoreboard sb;
pls let me know a solution
Chandra
Force10 Networks Inc, SJC
  • Shalom B
    Shalom B over 18 years ago
    Use a newer version of NC, and use the switch +sv.
    Shalom
  • tpylant
    tpylant over 18 years ago
    The current version of NC-Verilog is IUS81-s006. Therefore, the version you are using is quite old and may be lacking some of the construct support that you require. I definitely recommend installing a later release.
    For your current issue, I'm guessing that you have your class definition outside of a module or package which be considered the "compilation unit scope". This is not supported until IUS62. Move your class definition inside of your module and see if that removes the problem for IUS57.
    Tim
  • adua
    adua over 18 years ago
    Use irun to compile & simulate in a single step any/all hdl/hvl supported by Incisive platform.
    irun is a smart utility that can compile the file based on the default extension.
    Check the irun documentation in <ius_inst_dir>/doc/irun/irun.pdf
     rgds,
    Amit
  • chandanc9
    chandanc9 over 14 years ago
    Hi All,
     I am trying to run systemverilog files using :
    irun -f filelist .
    irun: 10.20-p008: (c) Copyright 1995-2010 Cadence Design Systems, Inc.
    TOOL: irun 10.20-p008: Started on Oct 23, 2012 at 09:54:13 IST
    irun
     -f filelist
      Globals.sv
      rtl.sv
      interface.sv
      top.sv
      Packet.sv
      Driver.sv
      Receiver.sv
      Coverage.sv
      Scoreboard.sv
      Environemnt.sv
      testcase.sv
    file: Globals.sv
    file: rtl.sv
    file: interface.sv
    file: top.sv
    file: Packet.sv
    file: Driver.sv
    file: Receiver.sv
    file: Coverage.sv
    file: Scoreboard.sv
    file: Environemnt.sv
    file: testcase.sv
      Caching library 'worklib' ....... Done
     Elaborating the design hierarchy:
     Top level design units:
      $unit_0x04bbcec2
      top
      output_intf[0].cb.read    <= 0;
    ncelab: *E,ASNUSE (./Environemnt.sv,56|12): Illegal use of a bit-select, part-select, member-select or mda element [9.3.1(IEEE)].
      output_intf[1].cb.read    <= 0;
    ncelab: *E,ASNUSE (./Environemnt.sv,57|12): Illegal use of a bit-select, part-select, member-select or mda element [9.3.1(IEEE)].
      output_intf[2].cb.read    <= 0;
    ncelab: *E,ASNUSE (./Environemnt.sv,58|12): Illegal use of a bit-select, part-select, member-select or mda element [9.3.1(IEEE)].
      output_intf[3].cb.read    <= 0;
    ncelab: *E,ASNUSE (./Environemnt.sv,59|12): Illegal use of a bit-select, part-select, member-select or mda element [9.3.1(IEEE)].
    irun: *E,ELBERR: Error during elaboration (status 1), exiting.
    TOOL: irun 10.20-p008: Exiting on Oct 23, 2012 at 09:54:15 IST  (total: 00:00:02)
    Environemnt.sv  has following:
    class Environment ;
    virtual mem_interface.MEM mem_intf ;
    virtual input_interface.IP input_intf ;
    virtual output_interface.OP output_intf[4] ;
    Driver drvr;
    Receiver rcvr[4];
    Scoreboard sb;
    mailbox drvr2sb ;
    mailbox rcvr2sb ;
    function new(virtual mem_interface.MEM mem_intf_new ,
    virtual input_interface.IP input_intf_new ,
    virtual output_interface.OP output_intf_new[4] );
    this.mem_intf = mem_intf_new ;
    this.input_intf = input_intf_new ;
    this.output_intf = output_intf_new ;
    $display(" %0d : Environemnt : created env object",$time);
    endfunction : new
    function void build();
    $display(" %0d : Environemnt : start of build() method",$time);
    drvr2sb = new();
    rcvr2sb = new();
    sb = new(drvr2sb,rcvr2sb);
    drvr= new(input_intf,drvr2sb);
    foreach(rcvr[i])
    rcvr[i]= new(output_intf[i],rcvr2sb);
    $display(" %0d : Environemnt : end of build() method",$time);
    endfunction : build
    task reset();
    $display(" %0d : Environemnt : start of reset() method",$time);
    // Drive all DUT inputs to a known state
    mem_intf.cb.mem_data <= 0;
    mem_intf.cb.mem_add <= 0;
    mem_intf.cb.mem_en <= 0;
    mem_intf.cb.mem_rd_wr <= 0;
    input_intf.cb.data_in <= 0;
    input_intf.cb.data_status <= 0;
    // Reset the DUT
    input_intf.reset <= 1;
    repeat (4) @ input_intf.clock;
    input_intf.reset <= 0;
    $display(" %0d : Environemnt : end of reset() method",$time);
    endtask : reset
     Please help me to rectify these errors
    Thanks and regards,
    Chandan
  • tpylant
    tpylant over 14 years ago
    We need to see the interface and clocking block since that is what it is complaining about.
    Tim
  • chandanc9
    Thanks for your kind reply. Following is the code for output interface :
    interface output_interface(input bit clock);
      logic    [7:0] data_out;
      logic    ready;
      logic    read;
      clocking cb@(posedge clock);
        default input #1 output #1;
        input     data_out;
        input     ready;
        output    read;
      endclocking
      modport OP(clocking cb,input clock);
    endinterface
     testcase file these interfaces are passed as :
    program testcase(mem_interface.MEM mem_intf,input_interface.IP input_intf,output_interface.OP output_intf[4]);
    initial begin
    env = new(mem_intf,input_intf,output_intf);
    then as above environment class has :
    function new(virtual mem_interface.MEM mem_intf_new , virtual input_interface.IP input_intf_new , virtual output_interface.OP output_intf_new[4] );
    task reset();
    which shows the error
  • tpylant
    Using IUS versions 10.2, 11.1, and 12.1, I had no problem in running this code:
    class Environment ;
      virtual output_interface.OP output_intf[2] ;
      function new( virtual output_interface.OP output_intf_new[2] );
        reset ;
      endfunction : new
      task reset();
      endtask : reset
    endclass : Environment
    interface output_interface();
      logic    read;
      logic    clock;
        output    read;
      endclocking
    endinterface
    module top;
      output_interface o[2]();
      Environment env = new(o);
    endmodule
    Do you get an error if you run this code? If not, what are you doing differently?
    Tim
  • chandanc9
    Thanks Tim. I am still getting the same error. I ran this code (modified calling reset task from run task )
    class Environment ;
      endfunction : new
      task reset();
      endtask : reset
    task run();
            reset();
    endtask : run
      logic    read;
        output    read;
      endclocking
    endinterface
    module top;
    bit clock;
    initial
            forever #10 clock = ~clock;
      output_interface o[2](clock);
    endmodule
    the log file reads:
    TOOL:   irun    10.20-p008: Started on Oct 26, 2012 at 10:58:10 IST
    irun
            tpylant.sv
    file: tpylant.sv
            interface worklib.output_interface:sv
                    errors: 0, warnings: 0
            module worklib.top:sv
                    $unit_0x7631bed7
                    top
    ncelab: *E,ASNUSE (./tpylant.sv,21|14): Illegal use of a bit-select, part-select, member-select or mda element [9.3.1(IEEE)].
    ncelab: *E,ASNUSE (./tpylant.sv,23|14): Illegal use of a bit-select, part-select, member-select or mda element [9.3.1(IEEE)].
    TOOL:   irun    10.20-p008: Exiting on Oct 26, 2012 at 10:58:11 IST  (total: 00:00:01)
    Is this problem due to tool version ?
    Chandan
  • Shalom B
    Shalom B over 14 years ago
    I don't have 10.20-p008, but this exact example runs for me in 10.20-s009.
    Shalom
  • chandanc9
    Thanks Shalom. Then it seems to be version problem. If anyone could please point to alternative
    -Chandan
