  3. Allegro Extract SYM_NAME
  • Views 15309
ns123
ns123 over 17 years ago
I am  trying to extract from Allegro the component pictures. I am extracting the SYM_NAME, but I wonder if this name is unique across all symbols. In other words, if 2 components are refering to the same symbol name, does it mean they have the same picture? or each component has his own symbol?
thanks a lot.
  • oldmouldy
    oldmouldy over 17 years ago
    It looks like "SYM_NAME" in the extract is the same as "Symbol Name" in "Show Element" and "COMP_PACKAGE" in the Component Report, (Tools>Quick Reports>Component Report)
    Where components in the board have the same symbol, "SYM_NAME" has the same value, for example, in the board, there are four SOIC14's and SYM_NAME gets extracted as SOIC14 for these four items.
  • ns123
    Thank you for your reply :)
    So you are saying that there is one SYM_NAME (symbol) and components refer to it. However, when I extracted the data, I had 2 components having the ssame SYM_NAME but each one has a different SYM_X and SYM_Y. Shouldn't they be same since it is the same SYM_NAME?
     Thank you.
  • oldmouldy
    The SYM_NAME is the name of the symbol, so you could have many components that reference the same SYM_NAME, the "unique" property would be akin to the "refdes", as in, U1, U3, U5 could all reference SYM_NAME SOIC14. Run a Quick Report for Componnet Report to see the fields that differ and are alike.
  • ns123
    Thanks again oldmouldy for your reply :)
    So, SYM_NAME is the name of the symbol that components refer to. So we can have components U1, U3, and U5 referencing SYM_NAME SOIC14 (as u just said).
    But, isn't SYM_X and SYM_Y also related to the symbol? How come the extract shows something like the following:
    REFDES    SYM_NAME       SYM_X       SYM_Y
    U1              SOIC14               100             100
    U3              SOIC14               200             200
    Shouldn't SYM_X and SYM_Y be the same all the time since they are for the same symbol SOIC14?
    Thank your for your time.
  • oldmouldy
    No, SYM_X and SYM_Y are where the symbol datums are placed in the design so, hopefully, SYM_X and SYM_Y are not going to be same for any two components (on the same side), otherwise they would be stacked!
    Again, try a Tools>Quick Reports>Component Report in PCB Editor, this will show the RefDes, Symbol Name and Location, and reflect the same data that you are extracting.
