  3. TestPrep Automatic- Allow pin escape insertion problem
  • Views 2968
archive over 18 years ago
Hi guys
Has any you used the Allow pin escape insertion feature on the Automatic TestPrep ?
i understand that this feature adds via (as ICT ) so it needs to check/move all traces in all layers where it wants to add a via.
I have a board of about 3300 nets and want to add ICT's to (only 2700 need ICT).
when running the the TestPrep with the Allow pin escape insertion  feature checked then the ICT insertion rate is very slow
and when i say slow i mean 63 nets proccessed in  11 hours (over night)
i have a strong PC with XP Prof with 1G of Ram and Allegro Preformance
when i run the same just without this feature then it finishes after about 1 hour ( with 3 passes - eg. 3 probe types enabled) (results are 1300 ICT added out of 2700 nets need ICT)
Has any of you used this feature ? with any success ?
am i doing something wrong ? or did i forget to do something ?
attached the testprep automatic form and general parameters TAB with checked features
thank you for the help
roby
Originally posted in cdnusers.org by robyd
    Roby,
    I have not seen this in the past but it has been a while since I asked TestPrep to add in a large amount of missing test points using the "auto insertion" feature.
    I have a couple tips for you that may help you figure out what is going on.
    1. Test Prep does not allows add test points if it creates a DRC. It something does not do a good job bubbling traces away from a newly added test point which can cause addition failures because it creating DRCs. I would recommend you check "Disable cline bubbling" in the Testprep Parameters form and see if you can get more test points in using via replacement. In most cases you can easily clean up the DRC that are left behind after the test point is added.
    2. Dynamic shapes appears to prevent the addition of test points using the "auto insertion" feature so I would remove them prior to running the auto insertion pass and see if you get a higher completion rate. Of course generate a Sub-Drawing of them to be added back in later.
    3. Hilite the nets that are missing test points and see if you could find a test point location that appears to be a good test site. Try to add a test point manually to an existing via and if it fails review the error echoed on the command line to investigate it further.
    Overall, during the fanout of the design I attempt to space the vias out is such a way so they can be used as test points so I never run into the situation that you have that no test point sites are available.
    Hope this helps,
    Mike Catrambone
    UTStarcom, Inc.
    Originally posted in cdnusers.org by mcatramb91
    Hi Mike
    thank you for the info
    but my main question was about the rate of  automatic testprep works
    i now deleted all shapes in the design an rerun it
    aftre 4 hours of work it processed 12 nets out of 3263 ( see picture attached )
    and it is still running ......
    i also run it with out the allow pin escape and it runs fast enough ( about 1.5 hours with 3 diff probes)
    another question i have about the manual ICT
    it only adds ICT (SMT) on via or trace or pad
    but if i want to add near an existing via / pad/trace ( and then connect to it ) it is not possible
    so i put it on a pad with DRC and move it and after that route to it ( very complicated !)
    is there a better way to add ICT on adense board ?
    same problem when i want to add ict over a trace in the middle of the net
    how can i do it ?
    i first added avia manualy then tried to replace it to ICT with no succes
    so i added a small trace out of this via ( on bottom ) and i was able to add on the line/trace a smt ICT - when tried to move the SMT ICT over the VIA got a DRC
    again is there a better way to insert a TH via ICT on a trace running on internal layer ?
    thank you
    roby Drath
    MEMTEK Elec Eng
    Roby,
    I sort of didn't answer your initial question. It is hard to tell what exactly is going on..
    It is running the old allegro no-via router router to insert the additional test sites.
    Sometimes the old router would run very very slow when you had your routing grid set too fine so I did a little test board and found out that this is still the case.
    My Test board ran for 10 minutes and was made up of the following:
    - 1 inch sq PCB
    - 10 nets
    - 6 components
    - Routing grid set to 1 mil
    What is your Routing Grid set to ? This sounds like the reason why it is running so long.
    Your question: "Manual ICT only adds ICT (SMT) on via or trace or pad but is it possible to add it near an existing via/ pad/trace"
    I believe what you are looking for is to stub off of a existing via/pad/trace. What I have done in the past is setup my TestPrep Parameters and develop a small script to stub off a feature then add a test point which I alias to a function key. Here is a small example:
    # Add test point stub script
    # Enter add connect command and select trace
    # to be tested prior to running this script
    setwindow pcb
    ipick 0 -100
    next
    testprep manual
    ipick 0 0
    done
    add connect
    # End of Add test point stub script
    Of course you will need to tweak the script a little to work for you.
    Your question: " first added a via manually then tried to replace it to ICT with no success"
    You need to define a Thru Via under the Padstack Selection tab and also check the Replace Vias box at the bottom for it to work correctly.
    Your question: "I want to add ict over a trace in the middle of the net" "better way to insert a TH via ICT on a trace running on internal layer"
    As long as you define a SMT TestPad Padstack under the Padstack Selection tab you should be able to add a test point in the middle of a trace. Note: This only works for traces on the external layers because it uses a surface pad not a Thru hole test point.
    Hope this helps,
    Mike Catrambone
    UTStarcom, Inc.
    Hi Mike
    thank you for the effort and the share of your idea's
    now i understand that a "OLD" router is involved i understand
    i see that there is a log being generated tprouter.log ( which i don't understand at all)
    but i found that it includs a time column which was in average 4-5 minutes i assume per try/via
    any way my board is about 110 Sq in and the grid was 5 mils.
    i changed it to 50 mils and rerun it
    now in ran about 5 min BUT... only 3 ICT inserted !! (2-3 seconds per try in the tprouter.log)
    tried with grid of 25 mils and it ran 14 minutes with 5 ICT !?!(7-10 seconds per try in the tprouter.log)
    another try with 10 mil grid (which is still running)  i get about 1 minute per row in the log file
    it seems that when the allow insertion is enabled that the regular via replacement or smt over trace (on bottom) is disabled - it is not logical !
    when i ran it with 5 mil grid with out the allow pin insertion checked so only pad stack replacement and smt ICT added on tarces was done there were 1300 ICT inserted in less then 30 minutes ( in a faster machine )
    when i understood that grid may cause the algorithm not to find possible ICT locations that also satisfy the grid i decided to lower it to 0.1 mil and run it without the allow pin insertion and see if i get a higher ICT count ( more then 1300)
    the result was the same i think i got the exact ICT count
    so my theory is not right !
    any way i understand that the preofrmance of the automatic pin insertion feature is less then POOR ! or else you can suggest any thing else?
    it is not working as expected.
    about the idea of script ( and alias) it is very good
    but it lacks in that the length and direction of the stub are different for each and every case.
    so i my idea is : (did not try it yet)
    after adding the stub as desired ( direction and length)
    to excute ( by funckey x "done;setwindow pcb;testprep manual;ipick 0 0;done;add connect"
    done ( of the previous add connect)
    setwindow pcb
    testprep manual
    ipick 0 0
    done
    add connect
    and then continue add stub to the next place
    do you thing it will work ?
    about the replace regular via to ICT one i probably did something wrong.since i have it defined in the replacment table TAB and it is enabled
    about my last question
    i meant that i want to add an ICT in amiddle of  a trace that runs in internal layer!
    so i want to be able ( theoretically ) to add a TH ICT VIA on the middle of an internal trace.and to benefit from the good push and shove feature of the allegro.
    so now after your tip about the script i guess i can change to fit this case also
    or else you have a better solution ?
    again thank you very much for your effort.
    Roby Drath
    MEMTEK Elec Eng
    Hi Mike
    one more thing i just found
    i decreased my max via displacement from 300 mil to 50 mil
    and tha process is faster but still relative slow to the try without the allow insertion
    max 300 mil displacement with 5 mil grid gives 3600 possible via sites to be checked
    while
    max 50 mil displacement with 10 mil grid gives 25 valid ICT sites to be checked !
    it still does not explain why when i ran it with 50 mil grid  ( and other 2 feature checked beside allow insertion)
    it only added 3 ICT's ?
    from one point of view you want small grid so more via's can be replaced
    form the other hand you want higher grid to reduce run time
    what is the optimum ?
    or maybe it should be run in 2 stages
    small grid without insertion
    and then ( in incremental mode ) higher grid with allow insertion
    what do you think ?
    so now i run it (with 2 stages ) and see after few hours what is the progress
    Roby Drath
    MEMTEK Elec Eng
